R
[email protected]
Greetings group.
A customer has given me the following pump to try to repair.
Grundfos.
TYPE:- JQ4 A-A-CVBP
MODEL:- B96001190 P1 9605
The pump contains a circuit board that would look at home inside a
computer.
The mains supply is converted to DC and is filtered.
One large sealed module appears to be the rectifier and power control
unit.
Three wires enter the motor, and another three connect to a pressure
transducer.
When turned on, the shaft turns a few degrees then stops. And a light
flashes
6 times, pauses then repeats.
Can anyone please tell me if the DC supply on the board can be
connected directly into the motor?
Which two of the three wires would I use and what polarity?
Thanks in advance,
Russell Griffiths.
Grundfos.
TYPE:- JQ4 A-A-CVBP
computer.
unit.
transducer.
flashes
Thanks in advance,
Russell Griffiths.
