I can't comment on Word but I do know the if you use Open Office and
have GhostScript, PDFCreator and a postscipt printer driver installed
then it is possible to......
Use the postscript printer driver to print an .eps to file from most
other applications.
Use Open Office and insert the .eps file in the document as a picture
and crop/resize or otherwise play with it.
Use PDFCreator to print the file from Open Office as a PDF.
The end result, assuming other things, is the presentation quality Jim
is looking for.
Here's an example....
http://www.genomerics.talktalk.net/test.pdf
There are a mix of pasted gif images in that along with the picture of
the transformer which was robbed from a Philips PDF. Zoom in on
various ones and you'll see the difference.
So, the answer in this case is Yes.
DNA
