D
[email protected]
Hello,
I'm trying to figure out a simple way in which to create a large,
static electric field (at least 10^4 V/m, if not 10^5 or even higher)
over a short distance (about, or less than, 1cm). Could I simply hook
some high voltage source up to a parallel plate type configuration and
put them close together? Obviously if the field is larger than the
dielectric strength of air this would have to be done in vacuum, but
are there any other special considerations for generating large
electric fields? Can this large field be created with "standard"
lab equipment?
lab equipment?
