S
Sam Goldwasser
OK, it's microcomputer controlled, so does that qualify as electronics
repair even if the micro isn't the problem?
This unit is about 19 years old and now has started leaking mostly
or totally when it's draining. The drain hose is in good condition
and is not obstructed. The water appears to be coming from the area
near the back of the horizontally mounted motor/pump assembly.
It's less than a cup of water for the entire wash cycle,
which a pan can easily catch, but of course these things will get worse.
I don't believe it's a hose or connection problem but can't rule that out.
Any info appreciated.
Thanks.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
Thanks.
