FUME EXTRACTOR
charger100
Oct 2, 2019
4
Oct 2, 2019
4
hELLO i am trying to make a fume extractor for when i am soldering . i want to pur 4 pc fans together.
probably 70mm.x70mm,i want to wire them up ,all the black wires and all the red wires
together then to a connector. and
then to a 12 v power supply . will this work. hope you can understand that.
13,766
13,766
If the fans are all 12 V and the power supply can deliver the current for 4 fans then this should work.
4 of these fans will probably generate a rather intense airstream. You may need to add a speed controller. Or use only one fan or 2 fans??
charger100
Oct 2, 2019
4
Oct 2, 2019
4
Thank you for your answer , it as helped me a lot.
