Jimmy
Hi
I have with no success called F&P Aust asking them what the following
error code may indicate - they suggested making sure the water hose was
not kinked <cringe>
Error - Wash lights ON are the 3rd 6th 7th & 8th light with a single
beep every second.
Description of events leading upto the error;
Power on
Initiate std wash cycle (med water, cold water)
Tub fills to low level marker on agitator arm
Bowl agitates slightly for 1 minute (or so)
then error lights come up - only way to stop error code is to power
off the machine.
I post to this group as I see in the past people have posted about F&P
washing machines.
I have checked the water level tube and made sure not obstructed (and
blew thru it to endure clear), ran some local spare parts places as
well, not to successful there as well.
I have a suspicion it may have to do with the water level part of the
machine.
Thanks in advance if you can help shed some light on the error code.
Jimmy
not kinked <cringe>
beep every second.
Power on
off the machine.
washing machines.
machine.
Jimmy
