John Devereux
We have an IP67 box with a membrane front panel with window. At
temperature extremes the air inside will change pressure, up to ~0.3
bar - enough to cause significant bowing of the window and probably
enough to break the adhesive seal.
I would have thought this is a common problem - is there some kind of
low cost pressure equalization/relief valve that can be fitted in the
wall of the box?
wall of the box?
