dieseltekkie
- Jan 25, 2012
- 7
- Joined
- Jan 25, 2012
- Messages
- 7
I'm trying to design a part for an engine that will control the exhaust valves on an engine much like that of a semi truck engine brake but I'm running into a bit of an issue with figuring out how to make the timing module. I need a trigger wheel, pickup sensor, and the stuff that will make it work to operate a small solenoid at just before top dead center of each piston. it is a 4 stroke 6 cylinder engine so every 120deg of crank rotation when engaged it needs to close the circuit on the solenoid and keep it open for a period of 25deg. any ideas? Don't worry too much about the mechanical aspects as I'm working that from another angle other than an idea for a tone ring. i thought about the flywheel but there is not a missing tooth or anything to designate as a timing point
