B
Bret Cahill
Would alternating a lot of capacitors and inductors in series
approximate a Slinky spring?
Bret Cahill
Bret Cahill
Bret Cahill said:Would alternating a lot of capacitors and inductors in series
Charles Schuler said:A simple model would be a parallel resonant circuit (RLC). L and C would
dictate the oscillation frequency and R the damping factor.
But, if you are talking about a slinky walking down a flight of stairs,
forget about simple models.
Bret Cahill
them as one capacitor and one inductor. The inductance adds: L1 + L2 +
L3.... and the reciprical of the capacitace adds: 1/C1 + 1/C2 + 1/C3....etc.
The result is a single capacitance, a single inductance and a single
resonant frequency. Apparently you are looking for a coupled group of
resonators each separate from yet dependent on the other. There are circuits
like this. Look up chaotic oscillators.
Ah HA! Finally a situation where mechanics is more sophisticated than
electronics!
We have a Slinky that can walk down steps and you guys don't have
anything to compare..
Na na Na na NA NA.
It probably wouldn't be too difficult to make an electronic "slinky"
that could "walk" down a voltage.
It would make a really obnoxious car alarm.
Is it too late to cancel this post?
electronics!
The analogies between the two are mostly simple ones. I little direct
experience, but I'll guess that finite element analysis would do a great job
of modeling a slinky doing slinky-like tricks. Bad news is that those
software packages are REALLY expensive (might be some low cost versions ...
again, not my field). Ansys and Comsol are two FEA tools that I have played
with (demos only). Neat stuff!
and we'll simulate it. ;-)
rolling down a hill or down steps for that matter.From the angular momentum POV it isn't much different than a ball
know all the potential energy for each step ends up as heat as theFrom the energy POV, since it doesn't accelerate from step to step we
Charles said:But, if you are talking about a slinky walking down a flight of stairs,
coils slap together.
It might not be that ugly a problem.
As long as no new auto alarms come out of this . . .
