I just had this whizz banger of an idea.
So, you know how you have PN junctions, I thought of another junction that you can make.
If you put resistance next to voltage in your circuit, you can call it a component in itself.
The positive resistance adds a load in using it. (So it has a weakness.) But the voltage next to it. (In series.) cancels the resistance in one direction, and youll get a higher amps in one direction than the other, kinda like a poor mans diode, that has a fair bit of load and leaks alot..
I think its safer not to add too much voltage, or youll cancel the resistance negative and youll start drawing towards the ETV, I think thats not the right way to use them. (But I dont actually know for sure, only just had the idea today!!!)
I think something funny was going on, but I saw that you can make amazing hydraulic pumps with a Tesla valve, which has a beautiful property of no moving parts, so if its that good for moving physical water, then its got to do something amazing in electronics too!
Even tho I know its simple, would u guys call this a Tesla valve too?
Its not exactly the same in a way that there is a leak coming out of that wire in your circuit, so nearby capacitors will be charged by it, thats the issue with it, but if u keep the voltage down, and use them in a more loady fashion - then not much will be coming out, barely touch the circuit I imagine.
