Even those would be dependent on how the PCB layout person laid out
the board.
One doesn't just lett the PCB layout person do anything he wants! There
are guidelines, groundrules, and quick-kicks to the butt!
He may not have used it that way. it wasn't required in
any sense.
It was on any work *I* did, whether I specified the transmission
interfaces or designed the entire system! The layout guy never did
anything outside the spec. Good grief! How do you think things are done?
Differential pairs weren't in wide practice (in the PC
realm anyway) until recently with EIDE.
The PC is hardly the end-all. ...and EIDE *still* doesn't use differntial
pairs. BTW, who was talking about differential pairs?
It has been around a while in
SCSI, and known about in parallel conductor data pass design for a long
time. They have allowed for higher speed signaling without reflections
or crosstalk over longer passes. That's cool. Speed is good. :-]
Sure, but much SCSI wasn't differential either. Better than IDE, but not
all differential.
You are right though, configured the way you bespeak.
I know. ;-) I did several interfaces with 50-pin IDC cables with
10 connectors spaced at .75". The quality of the transmission environment
really surprised me, but was a little low (80ish ohms, rather than about
110 for long cables, IIRC).
Maybe we can have those new vertically oriented (magnetically) hard
drives at 2.5" form factor or such, and have an array of them, all hot
swappable on SATA passes, and have a huge parallel set of SATA
conductors, all segregated from each other that way.
Why?
BTW, I'm less than impressed by SATA. There is little gain. If only
they'd packaged the power in with the signal cable...
A person could wear a belt that has a fault tolerant, one terabyte
RAID file server on it, field repairable, connected to a battery, and
backpack laptop. Everyone could wear a live video recorder!
Why? I'm happy with a couple of sub gigabyte USB sticks on my keychain.
....then again, I'm not much into video (radio on a stick, OTOH... ;-).
