W
WayneL
Hi
I have read a paper on Fabrication of highly ordered metallic nanowire
arrays by electrodeposition by Yin a Brown University, US. See link for a
copy of the paper.
http://optonano.engin.brown.edu/Publications/APL01039.pdf
This paper discusses, among other things, the deposition of Bi and Ni to
produce nanowires.
Yin grew nickel and bismuth nano-wire using AC electrodeposition for
applications of high density recording devices and sensors. Yin used an AAO
(self-ordered anodised aluminium oxide) film as the cathode and a graphite
bar as the anode. He states that electrodeposition of metal into the porous
alumina film directly following anodisation can take place only under AC
conditions. Producing either Bi or Ni nano-wires required different
conditions.
Yin also found that the frequency range used also affected the results
produced. Another point worth noting is that high quality deposition of Ni
could be obtained with AC frequencies from 10 to 750 Hz and for Bi the
optimum frequency range was between 10 and 100 Hz. He commented that this
was probably due to the double layer. However, if the double layer is the
main factor dictating the frequency response then surely the frequency he
stated would be a function of the electrode size? Thus his figure are
arbitrary as they do not have any dimensional data. And if he did use the
same size electrodes for both Bi and Ni deposition why would the frequencies
be different? Surely the double layer capacitance is the same for both
metals or am I missing something here or is the double layer capacitance a
function of the metal's atomic number? One thing that is obvious is that
Bi(83) is significantly heavier than Ni (28).
Could somebody possible help clear this up for me.
Cheers
Wayne
copy of the paper.
produce nanowires.
conditions.
Cheers
Wayne
