Dumb UPS Question
Discussion in 'Electronic Equipment' started by [email protected], Jun 16, 2005.
  1. Guest
    Sorry guys I feel kind of dumb asking this question... I have in front
    of me two UPSs, one a Powerware Prestige 1.5kVa, the other a BEST USP
    1.4kVa. Why is the BEST more than twice the size? I would think that
    given the same capacity they would be the same size.
    The Powerware uses 5 YUASA NPX-25 batteries whereas the BEST uses a
    single Johnson Controls 12V 75AH battery. The transformer in the BEST
    is simply huge, while in the Powerware they're three much smaller
    toroidal transformers. But both advertise nearly the same capacity.
    Is one significantly 'better', or has technology given us smaller UPSs
    for the same capacity?
  2. Looks like the heavy one uses a "proven technology" big 60Hz transformer
    while the other uses an SMPS style of transformer. The first will produce
    the 60Hz directly from the battery and makes it available on the secundary
    of the transformer, the other uses a high frequency, PWM like voltage to
    feed the transformer followed by a (60 Hz) filter on the output.
    petrus bitbyter
