Dave McMahon
Does anyone know what wattage a Dragster DW 124 sub is?
Thanks Dave
Thanks Dave
Scott said:Don't be so sarcastic. that was all i could see for wattage specs
from the website. if you are gonna be rude, use google and go find
the info yourself!
Guy Macon said:That's also uncalled for.
Could we please discuss engineering without the personal attacks?
Keith R. Williams said:This group (alt.engineering.electrical) does have *engineering*
in it's title. And by the way Tony, "average sine-wave power" is
also meaningless. It's *average power*, depending on the failure
mechanism "average" may be over a wildly different time scale. Of
course there are other failure mechanisms than power.
Louis Bybee said:It's from being driven to out hyperbole the competition, and marketing types
writing the ad copy without consulting, or taking the advice of their
engineering resources (but wait there's more! :-] ).
Visit one of the Home Improvement Box Stores, and check out the size of the
electric motor on a home use Air Compressor rated 5 hp, and greater. The
motor physical size being about that an honest 1 hp motor should be an
indicator for the knowledgeable buyer.
Larry said:You guys are whack.
If watts RMS is not used correctly then why do companies use the term around
the world?
On websites, product box'z and such.
Keith R. Williams said:Nope. This is an *engineering* group. no? As such people should
be using engineering terminology correctly. Sorry if you think
otherwise, dae!
Edward Steele said:RMS or Root Mean Square, as for putting dc through a speaker it WILL fry the
coil as a speaker is only designed to take AC, to find the peak wattage of
the speaker divide the RMS by 0.707
Keith R. Williams said:...and may your speakers sound "liquid" with your silver lutz
wire. ;-)
Well that has got to be the funniest I have seen for the month.
You can be sure of one thing on this NG....... BAD AND RUBBISH ADVICE!!!!
Note: you can apply DC to a voicecoil.
IIRC RMS is not simply Peak power *0.707
Tzortzakakis Dimitrios said:What??You pay two fucking cents for a message??
