I'm building an LED grow light, it will have about 30 parallel LED circuits. It is going to be powered by an off-grid 12VDC PV array.
The two key components are the Xantrex C35 Charge Controller and the Powersonic PS-1270 battery. The CC has two charge settings (Bulk and Float), with slightly different voltages (I can set them anywhere from 12.5 to 15.0 - the ideal for my battery is something like 13.4 and 12.5)
Since the loads and the CC are connected in parallel on the battery terminals, my concern is this: depending on the State of Charge on the battery, it seems like my LED circuit voltage could vary by up to 1V, which totally changes the size of the series resistor. To be safe, I could go on the high-resistance side, but I'm worried my lights won't light up under certain conditions.
I know there are products like this
http://www.ledsupply.com/04006-025.php
that would solve the problem, but they're expensive. Would this be overkill? Or does my application require something like the DynaOhm?
Thanks very much for any help,
Bret
Bret
