Do AC transformers use up the same current unloaded?
Discussion in 'Electronic Basics' started by Phil, Squid-in-Training, Nov 19, 2003.
  1. My question is quite simple, and I don't have much electrical knowledge. My
    laptop has an AC adapter that gets hot whether or not it's on. Do
    transformers of this sort draw the same amount of power when the computer is
    either on or off?
    Gateway M305CRV with the typical
    thick-wire-to-block-to-skinny-cable-to-cylindrical-power-connector.
  2. Its probably not a transformer but a switching power supply and it will be
    idling and not drawing as much curent when the PC is off and it shouldn't
    get as hot while idling.
    hank
  3. David Wood
    David Wood Guest
    No, but who knows what you've got? Maybe if you mentioned the
    manufacturer and part number of the power device you're concerned
    about instead of the device it's driving we could help you. There are
    exactly umpteen million of them made in the world and only a few are
    designed not to burn your house down.
  4. Don Kelly
    Don Kelly Guest
    If (and as suggested it may not be) it is a wall wart type of transformer
    power supply, the transformer portion may have fairly high no load losses
    (push core a bit to save $ and weight) and these may well be as large as the
    power required by the laptop and will be there as long as the power is on.
