WantonZoo said:
Hi all - I want to use a servo to move a model for a small head on my
shoulder. You know - my evil - attached to my shoulder twin? Anyhoo - is
there a way/simple circuit to control a servo without using RC reciever,
etc. Just a direct push button a it turns left then button b it turns
right?
Hi, Wanton. You and your evil twin will appreciate this hobbyist
circuit for making a servo control pulse from an LM556 (or two LM555s):
http://www.seattlerobotics.org/encoder/200210/servoex/ServoExcerciser.htm
A servo accepts a control pulse every 20ms. or so. The active-high
pulse width is the position control (the wider the pulse, the more
angle).
Just use a 10K resistor instead of the 10K pot on the 2nd 555, and
place your switch contacts across the 10K resistor. When the switch is
closed, the pulse will be short (and the head will move toward you).
When the switch is open, the pulse will be long (and your evil twin's
head will move away). This circuit provides two position control,
where the servo will travel end-to-end.
Simple circuit, runs off your servo's power supply, and all components
are commonly available at any hobbyist source, including Radio Shack.
Good luck
Chris
