D
Dungeon Dave
Further to my last post about having a dimmer circuit (using the Bowden
circuit mentioned previously), next stage is to try to replace to 50K pot
with something more remotely controllable.
The idea is that although I can manually turn up/down the dimmer, by
having it controllable from a variety of sources I can replace manual
control with either computer-based or timer-based (or a combination of
all three) - so I'm looking at something I can ideally feed in a
"increase" or "decrease" signal and it'll increment/decrement the pot
driving the Bowden circuit.
Is this feasible?
Lastly, I wouldn't mind trying to do the same circuit idea but for mains
lamps - like the Halogen dimmer circuits - to drive a set of Haloge
spotlights used for lounge uplighters. I once attended a conference in
which a rocker switch near the door was used to toggle on/off the lights,
but holding down the switch would increase/decrease light intensity,
allowing a light level dark enough to permit a projector to be used for
presentations but still with enough light that attendees could scribble
notes. The same switch was located over near the speaker's stand, as well
as near another control panel - it was clear that the circuitry lay not
behind the switch itself (as with some conventional rotary dimmers) but
elsewhere with several switches all paralleled up to provide the same
control from different locations.
Again.. should I hunt around for a circuit to do this, or is there some
off-the-shelf idea that I could utilise?
Is this feasible?
