Jean
Digital dimmer: Triac vs MOSFET in a circuit?
I want to dim a 120Volt-60Watt light with a digital controller.
I already have a circuit that use a Triac but I would prefer to use a
power MOSFET.
This is not the purpose of this post.
For the ones who want to know why I would prefer MOSFET, some reasons
are summerised at
http://www.epanorama.net/documents/lights/lightdimmer.htm
like these:
Reverse phase controlling has some advantages over traditional dimmers
in many dimmer applications. The manufactuers of inverse phase dimmers
adverstise their products to be more efficent and less noisy. Using
proper controlling electronics it is possible to build a reverse phase
dimmer without any magnetics or vibrations caused by them.
Because turning on point is always exact at the zero phase there are
no huge current spikes and EMI caused by turn on. Using power MOSFETs
it is possible to make the turn-off rate relatively slot to achieve
quite operations in terms of EMI and acoustical or incandescent lamp
filament noise.
For the ones who want to know the basic functionning of a light dimmer
with Triac:
http://www.interq.or.jp/japan/se-inoue/e_ckt24_2.htm
The Triac is turned on with the impulse current on the gate and shuts
off when the AC is zero.
The MOSFET turns on when the AC is zero and shuts off with the impulse
current on the gate.
Besides this basic functionning, my question is:
Is there any other considerations I should take into account by
replacing a Triac by a MOSFET in a circuit?
Do you have a dimmer circuit with MOSFET to suggest?
Where in the net I could have more information about light dimmer
circuit with MOSFET, IGBT...?
power MOSFET.
are summerised at
like these:
filament noise.
with Triac:
