Ya. I meant "streaming" not "steaming" I can't edit the headline. [mod edit: I did]
It has backlight but no image. I did the reset thing with the remote control and it did not work.
I assume I need to replace some boards, but want to know which ones.
The symptoms seem to indicate bad T-con board.
But this TV has no T-con board.
Is the T-con circuit built into the main logic board, or the narrow boards that feed the screen?
Anyway, I’d like to know the test points to test at to let me know whether to replace that main logic board. I assume the narrow boards that feed the screen cannot be replaced.
And I suspect the most useful test points to use would be on the narrow boards that feed the screen.
Can someone tell me which of such test points are most useful and what their values should be?
Most of the test points on the narrow boards that feed the screen:
VO1_CB or VO1_C8
VO1_>B
F_GATE
E_101
VREF
L_VAA
POL
SQIN
STVR
OE
CKV
STV
D_GATE
GP01
VP_F
GVON
BK_SEL
DE
TEST
L/N
E102
RST
LOCKN
HTFDN or HTPDN
E1012
GM11
GM10
GM8
GM6
GM3
GM2
GM1
SPI-GND
SPI_DI
SPI_CS
VDD_IO_33
SPI_SCK
SPI_DO
BIST_MODE
BIT_SET
3D_EN
SET_MODE
L/R_I
L/R_O
E1013
VDD1V8
VIN12
EN_1V8
SPI_VDD
ROM_SPI_EN
GM12
GM13
GM15
VO1_CB or VO1_C8
VO1_>B
F_GATE
E_101
VREF
L_VAA
POL
SQIN
STVR
OE
CKV
STV
D_GATE
GP01
VP_F
GVON
BK_SEL
DE
TEST
L/N
E102
RST
LOCKN
HTFDN or HTPDN
E1012
GM11
GM10
GM8
GM6
GM3
GM2
GM1
SPI-GND
SPI_DI
SPI_CS
VDD_IO_33
SPI_SCK
SPI_DO
BIST_MODE
BIT_SET
3D_EN
SET_MODE
L/R_I
L/R_O
E1013
VDD1V8
VIN12
EN_1V8
SPI_VDD
ROM_SPI_EN
GM12
GM13
GM15
