Often the ghosting is caused by the electrolytic capacitors on the CRT
neck board going bad or having high internal resistance. I use and ESR
meter to check these. The capacitors are usually small ones about 1 Uf
at 100 volts and are usually positioned near the video amp IC. If you
do not have an ESR meter, you might just want to consider replacing all
of them. They are cheap.
John
