Dead TVs
T
tundra
Friends of mine have recently had 2 new TVs go out within 6 months or so of
each other. Both were covered by warranty but I wonder if this is somehow a
voltage problem. First one was a crt tube type and the tube burned out after
1 1/2 years. Replaced it with an LCD which lasted only 3 months. They live
in a small town out in the boonies so I don't know if their power signal may
be poor. Any recommendation on how check this? Can electricians measure
voltage fluctuations? They don't have a good surge protector or power
conditioner but they didn't have one on their old tv for decades so they
figured they didn't need one. Are newer tvs more susceptible to voltage
irregularities? Anybody have an opinion on the value of a surge protector on
a tv? are things like power consoles (like a Belkin PF30 Power Console)
worthwhile
insurance?
SL
1 1/2 years.
A CRT burning out is most unlikely. I've never come across it or even
heard of it.
I think this is, while possible, not the most likely explanation.
correctly
irregularities?
no
worthwhile
insurance?
If youre on mains, their value is zero. For private generator supplies
theyre important, but hardly anyone runs electronics off a private gen.
NT
S
Sam Goldwasser
worthwhile insurance?
Make and models?
There are a lot of poorly made TVs out there. Bad power wouldn't cause
the CRT to go bad.
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
Y
Yukio YANO
worthwhile
insurance?
SL
Consider a "Floating Neutral" !
Can happen on ANY 110/220 grounded Neutral installation.
Will cause as much as 220 volts to appear on a normal 110 outlet.
This is NOT a line surge, but the end result is the same !!!
The most obvious symptom is lights that brighten and dim momentarily as
other loads cycle on and off, refrigerators, microwaves, air
conditioner, washers but not Dryers (runs on 220) and does not use the
Neutral except for the Dryer motor which runs constantly during the
drying cycle.
Yukio YANO
S
Sam Goldwasser
drying cycle.
Yukio YANO
Or a thousand other things, including just garbage quality TVs to begin
with! :) It's unlikely for any power problem to kill a picture tube.
Need more info. Make and model would do for a start.
K
Ken Weitzel
Hi Sam...
I agree, but the op said "the tube burned out"; which could
mean just about anything...
The set died, the picture disappeared, the raster disappeared,
etc...
Not necessarily or even likely that it "kill(ed) the picture tube" :)
Take care.
Ken
S
Sam Goldwasser
Ken Weitzel said:
Hi Sam...
etc...
Yeah, I guess that could very well be. :)
"My car doesn't go anymore so it must be a dead engine." :)
B
b
tundra ha escrito:
worthwhile
insurance?
SL
When you say new tvs, you need to give us the make and model if
possible.
chances are, the sets weren't much good to begin with, seems the norm
these days of disposable electronic consumerism.... SO many people tend
to be guided by shiny silvery appearance and low price rather than
build quality or brand reputation. Then the chickens come home to roost
when the things crap out after the guarantee expires... so then out
they go and buy another, new, equally shoddy piece of crap to replace
it with!
sorry, rant off now! ;-) no offence intended to the OP, just my pure
speculation based on experience....
-B
H
Homer J Simpson
of
a
after
may
Some modern DMMs can measure max - but a TV should run from 90 - 140 VAC OK.
on
Cheap and don't hurt - usually.
Plug-in protectors are cheap? Hardly. They cost typically tens of
times more money per protected appliance. Since they are missing that
short and dedicated earthing wire, then plug-in protectors may even
provide a surge with more destructive paths through an adjacent
appliance.
We traced path of a surge that damaged networked and powered off
computers. Confirmed that path by replacing ICs on the board and
restoring all machines. A protector does not stop, block, or absorb
surges. It is called a shunt mode device. It shunts - either to earth
ground or into adjacent appliances. They simply distribute a surge to
all other wires. If one of those wires is not the short connection to
earth, then a protector may shunt that surge to earth via a protector.
Effective protectors make the 'less than 10 foot' connection to
earth. Protector earths transients that would otherwise overwhelm
protection already inside appliances. Any protection that would be
effective on that computer power cord is already inside the computer.
Protection that remains effective if transients are not permitted
inside the building.
They are called 'whole house' protectors. Sold in Home Depot, Lowes,
and electronics supply houses are effective products from Square D,
Siemens, Cutler-Hammer, Intermatic, Leviton, and GE. Not mentioned are
products sold in Radio Shack, Walmart, Sears, Staples, Circuit City,
Kmart, or Best Buy. Effective protectors have that dedicated earthing
wire to connect protector to protection. Protection is the most
critical component in any protection system: earth ground. Just
another reason why the home earthing may need be upgraded to post 1990
National Electrical Code requirements.
So where in those numerical specs does the plug-in manufacturer even
list each type of transient AND provide numbers for that protection.
Notice no mention of protection in their numerical specs. And one
would call that cheap? Yes. So cheap to enrich its manufacturer and
yet provide no effective protection. It don't hurt the manufacturer.
And it also don't claim to provide that protection. Listed is
effective protection that costs less money. Defined are ineffective
plug-in protectors with hyped names and yet don't even claim to provide
Insurance with a plug-in protector? You wish. Review details in its
warranty. Chock full of exemptions. One even implied that if a surge
protector in the building was not manufactured by them, then warranty
is void. The list of exemptions like this are numerous. Warranty on a
protector only exists when one forgots to read details.
Effective protector makes a 'less than 10 foot' connection to earth.
Every homeowner should consider this many times less expensive and so
effective solution.
Meanwhile none of this is about low or high voltage. Transients
(volts of 10 or 100 times higher) that occur in microseconds have
little relationship to voltages that make minor changes in seconds or
milliseconds. Solutions to high or low voltages (140 to 90) involve
other solutions; other devices. Low voltages must never damage
electronics. Appliances must also withstand high voltages such as 140,
170, and 400 without damage depending on time.
Before discussing voltage irregularities, first define each with
numbers - voltage and time. A surge protector complete ignores when
120 volts climbs to 200 volts. See its box. Let-through voltage is
maybe 330 volts.
