David Masters
I am looking for something like a common flourescent or neon tube, but
one that runs on pure DC.
I don't mean it runs off an inverter but uses HVDC direct to the tube
to maintain ionization of the gas.
An AC ignition voltage would be OK as long as the tube runs on DC once
ignited.
I believe some cinema projection lamps do this, but they are far to
powerful and expensive in terms of power supply and heat generated.
Color, wattage or gas content does not matter, but the tube must be
cylindrical with diameter within the 10-30mm range. Length is not
critical.
What would be the best off-the-shelf solution for doing this?
Much thanks,
David Masters
ignited.
critical.
Much thanks,
David Masters
