Integrator741
- Jun 16, 2013
- 125
- Joined
- Jun 16, 2013
- Messages
- 125
Hi all,
I am trying to calculate maximum current drawn by daikin air conditioning unit.
On technical sheet it says maximum power is 6.6 kw.
So if I operate the unit at maximum power I draw 6.6/240 amps, don't I?
Now the unit is supplied by 1.5mm flex, which has current carrying capacity of 16 amps.
When I turn the unit on, it's working fine, but something is wrong with speed, because no matter what speed setting I press, the unit doesn't react. So I was thinking could it be the 1.5mm flex that's not giving enough current? Or something wrong with controls?
Thanks.
Thanks.
