You will need 6 channels.
Fr.L , Fr.R
Back.L , Back.R
Center, Sub
If you do not have these 6 channels, then you will need to rely on some kind of encoding scheme to send the appropriate audio to the appropriate speaker. This will be much harder.
Dolby Pro Logic II for example does this.
If you do indeed have these 6 channels... ie, from a computer sound card then by all means. You can progress relatively easily.
I have a pretty decent desktop with a 3.5 mm audio jack ( green ). I guess that is 2.0 . I currently use Creative 2.1 speaker set. If possible, I would like to build everything myself. So I will be needing a speaker set as mentioned by @Gryd3 and I guess amplifier as well as suggested by @BobK .
I will be using it in a medium sized room. I guess that will give some idea about wattage.
After you install a 5.1 or 7.1 capable card into the PC, you will be given the option to 'mimic' surround sound. Of course, you will have much better quality from an audio track that actually has the channels encoded. That and video games that support it.
As far as the card is concerned, most will simply give you more 3.5mm jacks which are commonly paired up as:
- Center + Sub
- Front Left/Right
- Back Left/Right
- Mid Left/Right (Only on 7.1 systems)
That, or they offer a digital coax, which is an orange or black RCA plug. This will carry digital audio to the amplifier which will decode and pass the appropriate streams to the proper speakers.
