Marvin Moss said:
I bought a non-frost-free freezer that frosts up too much and too
frequently. I want to convert it to a frost-free freezer.
Can I add a timer to the line input so it turns off for 30 minutes or an
hour per day so the ice build-up can melt?
Does a frost-free freezer have a water drain system that a non-frost-free
does not have to get rid of the melted water?
A frost-free has:
1. Its evaporator coils isolated from the freezer and fridge compartments
so that they can be heated without affecting the food.
2. A timer to control the defrost cycle. Something like 20 minutes
every 6 hours.
3. A heater to melt the frost during the defrost cycle.
4. A separate thermostat to tell the heater to turn off when the frost
is melted (gets to 32 deg F).
5. A drain system to get rid of the water to an area near the hot
condensor coils where it evaporates.
Could you convert to something that may be good enough? Possibly.
Depends on what you really need. Realize though that the normal
thermostat turns the compressor off periodically when the temps are
low enough and the frost doesn't melt on its own.
--- sam | Sci.Electronics.Repair FAQ Home Page:
http://www.repairfaq.org/
Repair | Main Table of Contents:
http://www.repairfaq.org/REPAIR/
+Lasers | Sam's Laser FAQ:
http://www.repairfaq.org/sam/lasersam.htm
| Mirror Site Info:
http://www.repairfaq.org/REPAIR/F_mirror.html
Important: The email address in this message header may no longer work. To
contact me, please use the Feedback Form at repairfaq.org. Thanks.
