This is a controller board of a low volume solar powered water pump (Jupiter 300LPH Solar Water Pump Kit by Bermuda), it was manufactured around 2010, currently out of production.
The controller functions are:
- On/Off
-Power pump through solar panel
-Power pump through backup battery
The controller charges the backup battery when turned on.
The controller has three momentary buttons:
-On
-Off
-Select function
when the On button is depressed the controller is switched on and functions can be selected.
The On switch has failed (or so I thought), when the On button is depressed it turns on as long as you are pressing it, once you remove pressure from the button, it turns itself off.
I assumed that the On momentary switch was faulty, so I replaced it, this has not resolved the issue, still the On button has to be continually depressed to function, which points to the fact that the fault lies elsewhere.
Searching the Internet for possible solutions, I came across a reviewer on amazon who said that he has suffered the same On switch failure, so I am hoping that this is a common problem (with an easy to fix solution).
I have no electronics knowledge beyond soldering/unsoldering, any help in fixing this controller is greatly appreciated, the cost of replacing it is out of my reach at the moment.
On the attached image, the On switch is top right, Off switch is top middle, function switch bottom right.
The following is a link to a help to setup page, which shows the complete pump and panel.
http://www.ukwaterfeatures.com/Guides/installing-your-new-solar-powered-water-feature.html
- On/Off
-On
-Off
-Select function
