infra_rabbit
- Sep 18, 2011
- 3
- Joined
- Sep 18, 2011
- Messages
- 3
I have picked up a Technics LW/MW/FM Stereo Tuner, model ST-X999L that someone dumped with his other HiFi equipment.
The unit appears to be in perfect working order but I cannot get to give an output to my amp, I suspect it is because it needs some control signal from the amplifier. This control link plugs into a 3 pin socket next to the Tuner's line output, and the other side plugs into the Amplifier.
Does someone know how I can make the tuner work without the amplifier control link, by simulating the right condition on the control pins?
I have been able to get a free download of a Technics amp with a circuit diagram (SU-X999). This shows the 3-wire cable between the tuner "Control" and amp. One pin is tied to +B supply of the amp. The other pin goes to the base of a transistor on the amp, and then from the transistor's collector goes with the 3rd pin to a microcontroller on the amp.
I do not know what happens on the tuner side.
http://www.download-service-manuals.com/manual.php?file=Technics-1627.pdf
