Winfield said:
[email protected] wrote...
Those have always seemed a bit too specialized and complex for my
taste, surely there's something better suited for this new common
problem. One doesn't need 3GHz bandwidth for most LVDS channels.
John, what about differential LEMOs? Maybe they aren't so bad?
I first ran into this problem back in the late 1980s. Within a rack,
the mixed signal DIN41612 connectors worked extremely well, letting us
plug in all the coaxial connections at once.
The hybrid D-types use the same coaxial inserts, but they come with
back-shells, screw locks and all the rest of the paraphenalia that you
need to make a reasonably tidy and secure connection between two
free-standing boxes.
They were much cheaper than LEMO connectors, and available off the
shelf, in small quantities - LEMO stuff (though quite beautiful) can be
hard to get hold of.
At that time we got all our hybrid connectors from the Quadrant
Connector company, who looked after Cambridge Instruments very well
indeed. They still exist but I don't know anything about what they sell
today, or how they sell it.
http://www.quadrant-ltd.co.uk/English/Products.html
The temptation to use multiple BNC or SMA/SMB/SMC connectors should be
resisted. No matter how carefully you label the cables, some idiot
graduate student/technician will plug them in in the wrong order, then
give you a hard time about your unreliable design.
The pleasure one gets from pointing out that the cables have been
plugged into the wrong sockets is no compensation for having to spend
half an hour walking around to the equipment and persuading the
offenders to look at what they've done wrong.
The first time we ran into the problem, we threaded all the half-dozen
coax cables involved through strategically placed holes in a perspex
plate (labelled the "monkey frame" by the technician who did the work)
before fitting the coaxial connectors.
We then bound the cables together close to the monkey frame and the
connectors so that there wasn't enough slack to let anybody plug the
cables into the wrong sockets. It worked fine, but wasn't elegant.
Since the machine was minimally improved copy of a Siemens-physicists'
development machine, which Cambridge Instruments then sold to
Thopmson-CSF, this wasn't the only inelegance. The production version
was quite a lot better, and the fully digitised version (which got
canned before we could get it into production) was an absolute dream
