Connect old stereo to PC
I wish to burn old 78 rpm records to CDs.
I have an old Stereo with a 78 rpm player but it has no output jacks.
There are external speaker jacks the old
full size ones.
What would be the best way to connect to a PC to record from the
phonograph?
Any suggestions will be appreciated.
M
Marc Guardiani
full size ones.
phonograph?
If you have access to the phono output, you can try this
http://www.dak2000.com/Reviews/2020Story.cfm
Let the DAK flames begin...
Marc
John
full size ones.
phonograph?
Make a voltage divider of a couple of resistors (1000ohm and 330ohn)
for each speaker line. --1000--330--
connect the open end of the 330 to the ground side (usually the
sleeve) of the speaker connector and the open end of the 1000 to the
other side.
Connect the ground side to the ground side of the sound card's LINE
INPUT connector and the junction of the 1000 and 330 to the other side
(center).
Enable the LINE INPUT on the sound card. Adjust the level as needed.
John
H
Homer J Simpson
phonograph?
Buy a TEAC GF-350
or Microsoft Plus! For WinXP
or Nero Wave Editor
G
Guest
discard old stereo, its more trouble than its worth.
get a used 16/33/45/78 turntable from salvation army/consignment shop/or
other .
it may be one of those combo /complete audio system types. make sure it has
turntable outputs (cost should be less than $10)
get a radio shack phono preamp, connct to turntable, connect output to sound
card.
preamp does most of the equalization, use sound software to "fix" the
resulting files.
expect to spend a day per disc to get decent results.
