R
Roveer
We had a customer call us this weekend after his alarm started beeping
at all the panels. He went to the basement pulled the power and all
the batteries to get it to stop. He made a real mess. The alarm
company came out this morning and found one of the keypads was soaking
wet inside. The display was fogged up and the PCB was definetly wet.
There was crystalization next to one of the chips which leads me to
believe this has happened before.
Question here is, what caused this? They insist they did not get this
keypad wet in any way. There is no indication of water in or down the
wall. All I can figure is this:
The homeowner has the inside temperature of the house set to 67
degrees F. Yes, it's actually set and making 67 degrees. The hallway
in question is probably a little cooler than that because it is right
off the main trunk and pretty well shaded, so lets say 65 degrees.
The keypad in question is right next to the garage door and the
outside garage doors are open almost all the time. The only thing I
can figure is that they had the door open (homeowner admits to
probably 15 minutes), and that the outside air (here in NJ for the
past two weeks it's been in the high 80's with 90-100% humidity) mixed
with the cold inside air and immediatly condensated on this keypad.
Has anyone ever seen this happen before? Our alarm guy says never in
18 years. Just wondering how this thing got soaked.
