I'm sorry for the delay in responding, I've been kept away from my desk
these couple of days, now it is looking brighter again.
It is just a regular general purpose light meter. I have an old folder
camera that needs some work. The first phase is to measure/fix shutter
speeds (mostly done) and aperture values. The next goal (after fixing
the camera) is to use it in photography to determine exposures. It is
connected to a microcontroller via 10-bit adc (0 - 5v). Once I get the
measurement data in, the rest is easily handled with software and
displayed with lcd.
Due to the limitations of adc I have about 9 bits to play with to
measure from darkness to sun. That should be enough for ordinary
photographic purposes (assuming logarithmic measurement).
Since measurement is mostly done in natural environment I assume that
the effects of tempcos in voltaic mode are significant.
They would be visible through adc within 2-3 degrees change of
temperature even without amplification.
I can either measure the temperature separately and compensate in
software (a lot more hardware) of try to eliminate the effects before
adc (hopefylly less hardware).
As you already may have surmised, I'm more at home with the digital part
of the operation than with the analog and need some help there.
Basically the operation looks like this (taken from earlier post, thanks
John!)
.-|/| | ___
Reading what you both said about the natures of tempcos, it doesn't look
like its too easy to compensate for them, even with an almost identical
part. I did a search on some application notes and couldn't find any
standard solution. I wonder if that is the reason why the
photoconductive mode is advertized so much. But then I suffer with the
adc. One can never win (the second law of thermodynamics
Jack
