Vindhyachal Takniki
- Apr 29, 2015
- 9
- Joined
- Apr 29, 2015
- Messages
- 9
1. I have two ac sources(from mains & generator) & have to run a circuit from it for which I need dc supply
I had connected a bridge rectifier to each source. After that each output is shorted.
2. Circuit is attached. It Actual circuit also has regulator & othe stuff, which i didn't show, I had only connected Rload & C.
3. There may be three cases: Only main available, only generator available, or both are available.
4. Is the circuit attached is safe.
5. I think problem may arrive when both ac sources are available.
Also it could be one may be at different angle then other. Like if first ac source have crest, other couls have trough or at some phase from each other.
