V
Vladimir Vassilevsky
Joerg said:There are very few good RF books and IMHO the best
are from the ham radio community. I could recommend a some really good
ones but except for the ARRL Handbook the ones here aren't in English.
The design of the high stability and low noise oscillators is the
special sort of knowledge, and there are quite many books about that.
This stuff is covered well in the professional books on the frequency
synthesizers.
SPICE and theoretical approaches are fine but at the end of the day
you'll have to fire up the old Weller and experiment. Find out the
boundaries, stability ranges etc. I found that transistor models for
SPICE aren't the cat's meouw when you approach the UHF range and above.
The SPICE model of transistor is OK, but it has somewhat 50 or so
parameters. Of course, most of those parameters are not even specified
by the manufacturers. There is also other problem with SPICE simulation
of RF: damn slow. The timestep is determined by the carrier frequency,
and the duration of a run is determined by the modulation.
DSP and Mixed Signal Design Consultant
http://www.abvolt.com
