A
Arch
Can anyone suggest where i can get the 50 ohm coax for UH-vacuum
applications?
thanks in advance.
applications?
thanks in advance.
applications?
thanks in advance.
I'd consider semirigid coax (Google "semirigid coax")
Solid wire center conductor, solid Teflon dielectric, solid copper
tube for the shield. May be low enough outgasing for all but EHV.
0.141" od is common, but there are smaller and larger diameters.
Might be an arcing issue at the ends of small diameters?
Pasternack has some, but 50-foot minimum.
Bret said:Try MDC Vacuum,
http://www.mdcvacuum.com/urd/uniface.urd/ecf0070w.display?6.1.e.3
This is bakeable to 260°C and claims it is designed for HV and UHV.
Bret Cannon
Thanks Bill,
If i don't get something inexpensive store - made , i will go the route
you told me to.
I dont think i get the glass-to-metal seals for the center conductor
part? Can we buy such wires with glass- insulator on them?
Arch said:Are there any ultra-high vacuum insulators which won't break at
cryogenic temperatures.
at cryogenic temperatures. Teflon may be the right choice?
