A
Alan B
You can buy a DMM for a lot less than a house call.
Agreed. How much does it cost to learn to use it intelligently?
cell phone:
input : 100-240V 0.2A 50-60Hz
Output: 5VDC 1A LPS
bluetooth headset:
input : 100-240V 0.15A 50-60Hz
Output: 5VDC 0.7A
I am not sure if they were not designed for Cyprus (240V )
Maybe I should seek the fault at my mains
But then again why other cell chargers and PC power supplies do not
blow?
Is it possible the specific socket is faulty?
interuser said:That makes more sense. Here the voltage is 240V and I guess it will not
be uncommon to go over 240V. I guess the manufacturers of devices
destined for Cyprus have this in mind and that's why I never had this
problem in the past with other devices.
These chargers have input range 100-240V but it is possible they are
not tolerant to fluctuations (although they were destined for Australia
- among others - where the current is 240V ).
One question remains though: is it possible the devices (cell phone and
bluetooth headset) were damaged or the damage stopped at the chargers?
I can tell the cell seems to work ok (apart for not beeing able to
charge a brand new battery)
Homer said:If these are 60 cycle chargers they will die on 50 cycle power.
interuser said:Is it possible the specific socket is faulty?
Homer said:You can buy a DMM for a lot less than a house call.
If the company making them cut the iron to the minimum that's very true.
Ebay ! About £2.50 !
I went to an electronics shop and they told me that I could replace the
5V 0.7A charger of my bluetooth with their 4.5V 0.8A transformer which
is the next best thing they have.
How would that work? Is it ok to use 4.5V instead of 5V?
The other option is 5V 2A but they said this could potentially damage
the bluetooth if not removed after a short period of time from the
mains.
Does the Amperage matter ?
probably.
Nothing in this group.
You have a lot of faith in the intelligence of those who gain random
access
via the internet. Just as an aside, how will a DMM help detect anomalies
in household electrical service?
test the voltage with a meter in that same socket.interuser said:cell phone:
Output: 5VDC 1A LPS
bluetooth headset:
Output: 5VDC 0.7A
blow?
Homer said:If he has 400 VAC across the outlet that would indicate a slight problem.
No, that would indicate a big problem
Homer said:That was irony. Having two phases on such an outlet is a bad thing.
If it helps, I put a lamp on that socket which did not show any
fluctuations in luminance.
But then again a lamp is not as sensitive as a charger.
Anyway Voltage quite more than 240V would burn the lamp.
Homer said:About $5 or $10 here. When I think what I paid . . . . .
But a Fluke is worth it !
