Jeanguypataterubberboot
- Jul 9, 2013
- 41
- Joined
- Jul 9, 2013
- Messages
- 41
Thanks Gryd3. You explain very well.
Pierre
Pierre
@Jeanguypataterubberboot Nice setup by the way!! And you said you were new in electronics If you look up reactance it may help you understand AC in a capacitor, very interesting stuff.
"Slow down, and open your mind enough to try to understand others and how they are using their words"
" I took a look at your post 27, and skimmed the replies and your getting into the same debate on other forums."
"Our languages are not perfect, and neither is our use of words. Keep that in mind when you read someone's reply."
"... but it is common to have it called 'charged'. Don't argue the word being used, argue the mechanics of the capacitor. Your nit-picking things that don't need to be."
"To address the charges accumulating on one side and depleting on the other... step back and take a look at the bigger picture."
"Yes, that is the end result, but the path of the 'charges' or electrons tell an external observer that the charge passes through the capacitor to a varying limited degree. Current goes in and current goes out. The exact mechanism here is that a different electron comes out, but the assembly appears to pass a current even though the individual components in the assembly do not. I agreed with you saying that 'electrons' don't actually pass through but energy, does. Now the mechanic here is the electrons' charge repelling other electrons, or the E-Field or whatever your region/school/teacher calls it. The mechanic is still the same. Electron gets forced onto one plate, which then repels an electron off the other plate which will then continue down the same path as if an electron had actually passed through. The surface area of course will dictate the rate at which this can actually happen, and the total amount of 'charge' or electrons that can pass."
"I will repeat my last statement, and say that both are indeed correct given your current reference."
"And we all know, a capacitor is made of two conductors."
"... but if you pick it apart and look at the individual pieces as you have been doing, each conductor is 'charged' with an opposite electric charge."
"We may not agree to the exact english word that must be used to describe each item, as there are numerous words in the English language that mean almost the exact same thing."
Thanks guys. Very informative discussion. I understand capacitors a lot better now. I am still a little confused though on the part that frequency plays in the capacitor. As the frequency goes up or down.
Pierre
Exactly. You assume that the 'conduction path' must be resistive, and since there is no resistive conduction path through a capacitor you maintain that there can be no conduction path through a capacitor. However, there is a conduction path through a capacitor that is capacitive in nature.
As I stated in the text you quoted, the electrons don't actually pass through, but they appear to. You dis-agree with me, then summarize a portion of my statement anyway. I have highlighted some key words I hope you notice when you re-read it."Yes, that is the end result, but the path of the 'charges' or electrons tell an external observer that the charge passes through the capacitor to a varying limited degree. Current goes in and current goes out. The exact mechanism here is that a different electron comes out, but the assembly appears to pass a current even though the individual components in the assembly do not. I agreed with you saying that 'electrons' don't actually pass through but energy, does. Now the mechanic here is the electrons' charge repelling other electrons, or the E-Field or whatever your region/school/teacher calls it. The mechanic is still the same. Electron gets forced onto one plate, which then repels an electron off the other plate which will then continue down the same path as if an electron had actually passed through. The surface area of course will dictate the rate at which this can actually happen, and the total amount of 'charge' or electrons that can pass."
No, the electrons only appear to pass through the capacitor. It is deceiving. As I explained before, the electrons get stopped at one plate and accumulate. The electrons at the other plate start to flow and deplete. This is caused by the voltage applied to the terminals, not by the repulsion of the electrons. I explained that before, too. This movement of electrons or current can only be sustained for a limited time.
When you see a current flowing into one side of a capacitor and a current flowing out of the other side, the capacitive conductive path is the part of the capacitor that allows that to happen. It should be self-evident.I still don't know what you mean by a capacitive conductive path.
Gryd3 said:"Slow down, and open your mind enough to try to understand others and how they are using their words"
RATCH said:Speed is irrelevant. Precision of expression is important when explaining something.
Gryd3 said:"We may not agree to the exact english word that must be used to describe each item, as there are numerous words in the English language that mean almost the exact same thing."
" Re-read my post and your response. This is why I'm telling you to slow down."
"Don't argue for the sake of argument"
" You've dismissed all of everyone's points if they are not word-for-word the same as your text."
"Chill your shorts. I understand what you're posting and am not attacking you if it feels this way."
"As I stated in the text you quoted, the electrons don't actually pass through, but they appear to. You dis-agree with me, then summarize a portion of my statement anyway. I have highlighted some key words I hope you notice when you re-read it."
" I have merely been expressing the same ideas with different frames of reference... ie looking at the capacitor as a whole, verses looking at it's components that make it up"
"...English language evolves and is not black& white."
" If the majority of people call it charged, then that is it's new definition and you need to learn to interpret how other people use their words. We are human, not machine, you need to learn to be more open minded and consider other opinions before opening your mouth."
And yet current flows through the capacitor. If current did not flow through the capacitor it would be a violation of Kirchoff's Current Law. Imagine a circuit which includes two nodes connected by a capacitor. The node equation for the summation of the current at a node contains a term for the current through the capacitor. It is easy to see that this is so by taking the Laplace transform of the circuit, where the current through the capacitor is expressed by the term (V1-V2)/(1/Cs). Looking at the operation of a capacitor in the complex frequency domain is just as valid as looking at it in the time domain, and conceptually easier. But the fact is that Kirchoff demands that current must flow through a capacitor. So if you accept Kirchoff's Law, then there must be a capacitive conduction path that exists.There is NO flow of current between the capacitor plates via the dielectric...
The current flow as described by a flow of electrons does not actually flow through it due to the dielectric. There is an inbound and outbound current flow, but the actual path of the electron does not continue through the capacitor.And yet current flows through the capacitor. If current did not flow through the capacitor it would be a violation of Kirchoff's Current Law. Imagine a circuit which includes two nodes connected by a capacitor. The node equation for the summation of the current at a node contains a term for the current through the capacitor. It is easy to see that this is so by taking the Laplace transform of the circuit, where the current through the capacitor is expressed by the term (V1-V2)/(1/Cs). Looking at the operation of a capacitor in the complex frequency domain is just as valid as looking at it in the time domain, and conceptually easier. But the fact is that Kirchoff demands that current must flow through a capacitor. So if you accept Kirchoff's Law, then there must be a capacitive conduction path that exists.
If you want to pass a note to someone behind a pane of glass, you can stick the note to the glass, then they see it and re-write it and continue to pass it around. The message continues on a different physical note because your paper cannot pass through the barrier.
If no one knows the layout of the building, it appears as though the note that goes in also comes out... The path is not 'through', because of the barrier. But the interaction at the barrier allows the path to appear to behave this way, even though internally it does not.
Tried to make a similar analogy with magnets further up, as I felt it more closely resembled an electron, but I figure I didn't quite explain it correctly to get my point across.Nice analogy. I like it. Ratch
So are you making an appeal to illusion & magic? Or are you stating that device characteristics specify how a device operates at its terminals?...it appears as though...
With any two-terminal device where current flows into one terminal and out the other terminal, current is flowing through the device. There is no escaping that realization....current flowing in and out of either plate DOES NOT constitute as a current flowing THROUGH...
Magic!So are you making an appeal to illusion & magic? Or are you stating that device characteristics specify how a device operates at its terminals?
It is obvious that fluid flows through the device, until it stops flowing. But unlike a capacitor, you have introduced a non-linearity. Nevertheless if the pressure keeps increasing in an attempt to cause more fluid to flow, the device will eventually fail -- just like a capacitor.Looking at this device, can you say that there is a path for water to flow?
