I
ivan
John Fields said:I have short circuited R and saw an increase of 15Vpp. By changing the cap
type I see from worst (50Vpp) to best (120Vpp). Would ESR variance be high
enough? What are the typical values of ESR? Unfortunately I do not have the
means to do a proper study on this here...
Earlier you stated that your circuit looked something like this:
(View in Courier)
Er
+----[7.37E-4H]--+--[2.2E-9F]--+--[22R]----+
[GEN1] [GEN2]
GND GND
Where GEN1 and GEN2 are square-wave sources with their outputs 180
degrees out of phase and Er is the voltage measured, to ground, from
the junction of the capacitor and the resistor.
From the values you've given, the circuit is resonant at:
1 1
f = -------------- = ------------------------------------
2pi sqrt(LC) 6.28 * sqrt (7.37E-4H) * (2.2E-9F)
~ 125kHz.
and the reactances of the capacitor and inductor will be:
Xc = Xl = 2pi fL = 6.28 * 1.25E5Hz * 7.37E-4H ~ 578 ohms
Now, since the signs of the reactances are opposite to each other,
at resonance they'll cancel and you'll be left with only the
resistance of the 22 ohm resistor, the resistance of the wire in the
inductor and the equivalent series resistance (ESR) of the capacitor
to limit the current through the circuit. Just for grins, if we
assume an ohm for each, the total series resistance in the circuit
will be 24 ohms.
Now, in order to determine the current in the circuit we'll need to
determine its impedance, thus:
Z = sqrt (R² + (Xl - Xc)²)
= sqrt (24² + (578 - 578)²)
= 24 ohms
Assuming you're driving your circuit with 5V sources, the maximum
current you'll be able to pump through the 24 ohms will be:
E 5V
I = --- = ----- = 0.208 ampere
R 24R
but because the reactance of the capacitor is 578 ohms, the voltage
dropped across it will be a startling:
E = IR = 0.208A * 578R ~ 120V
ok I understand, It looks like this capacitor has a 2R series resistance
then.
and the other which swings at 80V has a series resistance of 14.125R as:
80V / 578R ~ 0.138A
5V / 0.138A = 36.125R
36.125R - 22R = 14.125R
yeah I see what you are saying now...
Now, assuming that your generators can deliver the current and you
short out the 22 ohm resistor, the reactances will still cancel and
we'll be left with 2 ohms of resistance to oppose the current. That
means the current in the circuit will be:
E 5V
I = --- = ---- = 2.5 ampere
R 2R
and since the reactances haven't changed, the voltage dropped across
the capacitor will be:
E = IR = 2.5A * 578R = 1445V.
I get about 160Vpp here actually...
for those who asked, the complete circuit is roughly as shown at
http://www.atmel.com/dyn/resources/prod_documents/doc4684.pdf
in Figure 4-1. The signal and the resonant branch I refer to are COIL1 and
COIL2...
So, it looks like just shorting out the resistor will get you a
voltage increase of:
1445
------ = 12 = 1200%
120
There are also some second order effects like the inductance of the
inductor changing as the current (and frequency) through it changes,
and the parametric effects of dielectrics causing capacitance change
with voltage which will spoil resonance.
Of course there are always the primary effects, which in your case
involve the capacitance tolerances of the capacitors you're using
and their ESR's (losses) which could easily explain the results
you've been getting.
Here's an LTSPICE circuit list of your circuit which you may find
interesting:
ok I'll try this...thanks!
