Phil Allison said:
"Martin"
** If you read all four posts from the OP it transpires he has a small,
iron transformer plug pack with *CONFLICTING* AC voltage labelling. The
unit has two *angled pins* that fit into an Aussie outlet and *NOT * a US
one. When plugged in, it produced a sensible reading of 32.7 volts on his
DC meter. A 10uF, 35 volt electro inside the equipment exploded when the
supply was used.
The only sensible explanation is that the particular plug pack is produces
unfiltered DC - typical of ones intended for battery charging duty.
............. Phil
Yes, I read that later... Just goes to show that people really should learn
to include ALL the relevant info up front. As he did tell others that it
was 120VAC and then down the track mentioned "oh, it's 240VAC" just proves
that the OP's abilities are questionable... One wonders if he should be
trusted with a soldering iron? One also wonders if the plug pack polarity
was reversed hence the destruction of an electrolytic cap in the
equipment.... Doesn't seem that the voltage would've been enough to blow
that value cap like that, assuming that is we've been told accurate info and
don't find out down the track something different........ Unfiltered DC
wouldn't be enough to blow a cap like that - a capacitor is used to filter
DC, unless the plugpack is pumping out pure AC and not rectified unfiltered
DC at all... But he did, eventually, mention a 1000uF cap inside the plug
pack that has NOT blown so it must be rectified, (kind of) filtered DC.....
Back to polarity?????
