Can I replace PLC with microcontroller for project
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
A PLC has essentially a micro controller as its core, the difference is that the PLC has all the I/O conditioned with Opto modules etc.
Another nice feature of a typical PLC is that the (ladder) logic can be displayed on a PC screen and the (on/Off) condition of each I/O can be seen.
You could however make up I/O using Opto22 modules etc.
A micro should be equally as efficient, if not more, as a PLC has an update time taken to update all I/O conditions table.
M.
Nanren888
Nov 8, 2015
622
Nov 8, 2015
622
Some PLCs do a lot of conditioning of inputs for you. For example, you tell it that you only want to create an event when some signal changes beyond a particular amount, or out of some control zone.
Some also have support for various commonly-used functions.
The standards define multiple ways to programme them, ladder logic, structured text, often something that looks like microcontroller assembler, but runs on a virtual processor.
That hardware signal conditioning that Minder mentioned, opto isolation and often filtering is often really useful.
So, in a similar way to Minder's answer on the hardware signal conditioning, nothing that one can't implement oneself, but often a PLC is a very convenient way of doing it all with a minmimum of work.
There are some really small PLCs by the way.
Bluejets
Oct 5, 2014
6,942
Oct 5, 2014
6,942
Old pc system that I use for a crank grinder for miniature engines.
Might be useful for reference so you can get some idea of the complexity of starting from scratch so to speak with a uC.
  • dciplc5.zip
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
A PLC should be perfectly capable,
The operation appears to be a point-to-point procedure which is well within the capability of a PLC.
An issue often appears when servo positioning is required, especially if interpolated moves are required.
Some PLC's have add-on modules to take care of this, but gets expensive.
M.
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
It' seems PLC is not efficient for the project
If your concern was because I mentioned the relatively lower I/O refresh rate for the PLC, it would inconsequential, especially in this application.
M.
