Hi all!!!
I want to find the position of the ball valve, so i am using magnet fixed to the ball valve and when the ball moves the magnetic field is varied and it is detected by my hall sensor... And this hall sensor signal is acquired using Data acquisition which is 4 meteres away from the hall sensor..
Now my problem is how can i cable the hall sensor tat long and the cable should be able to withstand high pressure... if there is any further clarifications in my question, pls ask..
The cabling as shown above will be good for long distance measurment and pressuer withstand?
thanx in advance
thanx in advance
