Standuhman
- Jun 6, 2012
- 5
- Joined
- Jun 6, 2012
- Messages
- 5
Hello! I was wondering if anyone here could give me some advice as to how many amps a capacitor can handle, since they don't have an amp or power rating.
To make a long story short I'm trying to bring back a lead acid battery I salvaged from the recycle drop off. The battery started off having 2.44V, and after adding RO water to the cells it dropped to zero. Charging it with a power supply from an old printer brought the voltage up to 4V, but then after I read that the process worked faster the warmer the battery was, and after heating up the bottom with a battery pad, the voltage dropped back down to zero. I think that the lead sulfate in the bottom probably got disturbed and shorted the cells out. Since then I haven't had much luck in getting any charge into the thing, the voltage reads zero with the 'charger' plugged in or not. I thought I might have better luck adding a capacitor to the circuit, but doing so only resulted in the capacitor overheating, bulging out the bottom and getting electrolyte on my table.
Since I was well within the voltage rating I'm wondering how you know how much power a capacitor can take???
The capacitor is rated for 63V, 2200uF and 85degreesC and my power supply puts out 20.5V(18V when in circuit) at 2.23 amps.
What am I missing here?
