Is there a clever way to create a +-12V bipolar supply for the field?
It will be powering op amps on a PCB.
Could I use two 12V batteries in series? Or does the positive side
voltage have to the exact same manitude as the negative side voltage?
Ken C
Hi, Ken. You can connect two batteries in series as mentioned by Pete
S. Connect the - terminal of battery 1 to the + terminal of battery
2. Then, the + of battery 1 will be +12V, the connection will be 0V
or common, and the - terminal of battery 2 will be -12V. That may be
the easiest way to do it, and is probably the best way to go for a
newbie. It also has the inherent advantage of very low power supply
noise and no ripple.
There are a number of "clever" ways to do this, which don't require
lugging around two gel cell batteries (kind of heavy, take up quite a
bit of space). You can use a DC-to-DC converter, which will convert
4.5V or 6V (three or 4 AA or C batteries) into the +/-12V you need.
Mouser has the Datel BST-12/105-D5 3 watt W DC-DC converter that will
do this job, for $28.60 in single quantity.
http://www.mouser.com/index.cfm?handler=home
Or you can use two 555s to build a voltage doubler and a voltage
inverter to convert +6V into +/-12V (less a couple of diode drops).
But both of these solutions will add power supply noise considerations
into your circuit that you might not need.
Most old split supply op amps like the venerable (and practically
obsolete) LM741 are specified for "balanced" split supplies, but
they'll work perfectly well as long as both supplies are more than 3V
higher/lower than the input voltage range. I don't believe this was
true for the uA709, LM101 or some of the real fossils, but they're
gone, anyway (thank St. Liebowitz!).
I'm wondering, though, whether you might better spend your time
looking at other options, if your project isn't "in the can". Single
supply op amps have been very common for over twenty five years. Most
anything you can do with the old split supply op amps can also be done
with single supply ICs with a little craftiness. And that will solve
your problem of portable split supplies.
If you care to post again with more information, you might learn how
you can run your project on a single supply with three or four AA
batteries.
Good luck
Chris
