blunbintles said:
n00b questions: 1) what exactly is a bipolar power supply?
It's basically a power supply that has equal positive and negative
rails with respect to a common ground. i.e. +/12V
So a bipolar supply will have a positive terminal, a negative terminal,
and a Ground (or Common) terminal.
They are used most for analog devices like amplifiers that need to
accept and generate positive and negative signals.
3) can i use a PC power supply to power an amp that needs a
Most likely.
A PC power supply has both +/-5V and +/-12V outputs, so if it has the
current and other specs you need then it will work. It's common (no pun
intended) to turn a PC power supply into a bench power supply for all
sorts of purposes.
Sometimes they need to be modified though, to ensure that the don't
shut down under minimum loads etc. Should be plenty of info out there
on doing this.
