Best Low-Light Low-Cost Security Camera?
Discussion in 'Electronic Repair' started by gmark, Jun 27, 2007.
  1. gmark
    gmark Guest
    Anybody have recommendations for a low-cost security camera that's
    actually good in low light?
    Are the units integrating IR LEDs any good?
    TIA!
    Mark
  2. Anybody have recommendations for a
    Not really. All of the low-cost cameras
    I've seen were pretty poor in low light.
    It depends on what you want to accomplish.
    Most of the inexpensive cameras with IR
    arrays have such weak illumination that
    you can't tell who is there or what they are
    doing beyond a few feet.
    Regards,
    Robert L Bass
    Bass Home Electronics
    941-925-8650
    4883 Fallcrest Circle
    Sarasota · Florida · 34233
    http://www.bassburglaralarms.com
  3. ransley
    ransley Guest
    Try www.supercircuits.com they have one that goes to 735 feet, they
    carry one for every budjet
  4. George
    George Guest
    Low cost and good seldom travel well together. If you want a usable
    image you will need to spend some money.
  5. Just Looking
    Just Looking Guest
    Try a Bosch VDN-495V03-20.
    This is not for folks looking for bargain cameras.
  6. Guest
    I have one of those round bullet shaped wireless IR cameras I found on
    Ebay for about $10, they are usually more like $30 or so. If you are
    looking at something within 15 feet or less you can tell the
    difference between a cat and a raccoon but don't expect much more than
    that. It is more like something you would use to see if the wind
    tripped your motion light or whether it was a crtitter, human or
    otherwise.. I doubt the picture would be evidence in court.
  7. buffalobill
    buffalobill Guest
    from buffalo ny:
    regarding your project, your who/what/where/when/why/how answers will
    narrow down your choices, some ir's are visible as red at night, if
    your front porch camera is indoors behind glass those lights will
    cause a reflection. maybe your camera needs to be in an outdoor heated
    enclosure to monitor a basement water meter subject to freezing for
    example. to me i needed a wide viewing angle and low lux for the front
    door. the color cameras usually shift to black and white after dark,
    so you need to review specs if you need more light. a simple indoor
    installation to monitor a wandering grandma might be a simpler indoor
    camera on a motion sensing alarm trigger circuit related to a full
    door and window triggered home alarm. may i suggest you browse your
    camera needs here, i have purchased from this ebay seller, a favorite
    of mine, and he has excellent item descriptions:
    http://stores.ebay.com/Dennis6z7a
  8. Best low light camera I have used is the Extreme CCTV monochrome cameras.
    Check out a shot I just took over the internet from my remote DVR. The
    camera is looking through a front window. You can see the siren in the upper
    right hand corner of the photo.
    http://www.geocities.com/noweldrecumbent/CAM1.JPG
    Keep in mind the DVR is set at the lowest resolution, at 1 frame per second.
  9. Crash Gordon
    Crash Gordon Guest
    not bad for the lowest...what's the best look like?
    upper
    second.
    | Dave
    | >> TIA!
    | >> Mark
    | > from buffalo ny:
  10. Guest
    I saw your post about the low light cameras. Which camera model is
    it and
    what is the website address?
