darren adcock
- Sep 26, 2016
- 463
- Joined
- Sep 26, 2016
- Messages
- 463
Hi All. Not been on here for a quite a while as lost my workshop and ongoing back issues are causing me to change the way I work.
Anyhow, I've made a small area in my flat and am in need of getting a smaller in size bench power supply if one exists, also with ongoing back problems the lighter the better, but smaller is priority?
At the minute I'm using a Rapid electronics DC HY3002-3 - "The Rapid HY3002-3 is a Digital Triple Output Bench Power Supply. This power supply has three independent output channels: two of them provide adjustable output of 0-30V and 0 to 2A, while the third has a fixed output of 5V DC 3A"
Dimensions are; Width 260mm, Lenght 315mm, Height 155mm
https://www.rapidonline.com/rapid-hy3002-3-triple-output-bench-psu-led-2x0-30v-0-2a-1x-5v-3a-85-1921
I run it in dual rail configuration for -12v/ 0 / +12v... it would be good to have the option to run at -15v / 0 /+15v also but not essential
Also defo need, short circuit protection/current limiter/reverse polarity protection
I've had a look around but thought I'd ask here as figured there might be recommendations from folk who have experience of specific models... money isn't too much of a problem as it will be an investment so i can carry on building.
I've still not had a chance to finish my PSU whch you guys were helping me with, I've decided to start again with a ready made alluminium case to make sure there are no bends/strained wires which I could forsee being a problem further down the line, I hopefully will be redoing that project around the middle of May, and will post in the thread.
Thanks in advance
Darren
Thanks in advance
Darren
