Hi all,
I'm in the process of building a sculpture which is in essence a very simple battery-operated lamp, using LEDs hooked up in parallel (each with a resistor). I'm trying to figure out the most appropriate solution for powering it, and am pretty sure that I want to use one Li-ion cell (3.7-4.2 V) as it seems the closest easily obtainable voltage source to my needs (~3.3Vf).
My assumption had been that I should buy an 18650 battery and an appropriately sized battery holder with leads, but I then got to thinking perhaps it would be more compact and economical to use an aftermarket proprietary battery pack (eg for a digital camera) running at the same voltage.
My question is, is there anything in those battery packs that would prevent them being used to power other things? Also, I would assume that they're always protected cells, but of course the specs aren't readily available. Anyone able to shed any light?
Thanks so much!
Jared Friedman
Thanks so much!
Jared Friedman
