Robert Anderson
- Dec 24, 2014
- 3
- Joined
- Dec 24, 2014
- Messages
- 3
I am trying to repair a 20 something year old 10 amp Cliplight 12V charger. There are 2 components on the circuit board inside the charger that look like resistors, but are dark grey in color with 2 black bands. One end looks like it may be white. These components are 6 mm long and about 1.5 mm in diameter with a slight bulge on each end. One of the 2 grey components is obviously burned. I think this component is likely the problem. Printed on the circuit board below the failed component is "W1". Below the non-failed components is printed "W3". For what it's worth - resistors on the circuit board are brown in color and labeled "R1", "R2", etc.
I do not know what the abbreviation "W" means and cannot find it on any list of electronic component abbreviations. I removed both grey components from the board to measure their resistance. The one in good condition reads 0.1 ohm in both directions. The failed one reads 19.3 kohm in both directions.
What are these grey components? How would I determine the rating of a replacement?
