Please review the attached schematic and let me know if it will work for the below described application.
I am making a locking electronic treasure box based on a home built perfboard Arduino. There will be an internal 9v power supply but I also wanted a way of "jump starting" the system and automatically opening it from the outside if the internal batter dies or if you simply forget the access code. So there will also be a way to supply an external "emergency" power supply (via a 9v or higher power source). When you supply power to the hidden external positive and negative leads the Arduino will power up and Pin 1 will go high, thereby automatically opening the box.
In order to save battery power I'm using a DC-DC switching power module that can take in anywhere from 7v to 28v and output 5v with up to 92% efficiency.
I'm an electronics beginner and I have pulled together the attached plan for my circuit from various places. Don't hold back and please let me know if I have hit the mark or royally screwed up. Thanks in advance for your help!
