AV Receiver help
pentzy
Oct 26, 2013
3
Oct 26, 2013
3
i just purchased a pioneer vsx-822k av receiver for my house. I had a sony home theatre system with sony surround speakers, which i am currently using. The house is wired for sound and AV, but my problem involves the subwoofer. The subwoofer uses wire +/- connections but the av receiver uses an orange input plug. Can i use a wire connection with the input plug or do they both need to be the plug? what can i do? surround just isnt the same without the sub.
14,271
14,271
hi pentzy
welcome to the forums
"orange input plug " tells us nothing ;)
hopw about some photos of the back of the unit showing us the socket connection for the sub-woofer, your sub woofer cable and anything else that mite help us help you :)
cheers
solo2racr
Aug 21, 2013
142
Aug 21, 2013
142
Just a guess but, I would say that the sub is unpowered and the receiver requires a powered sub.
Photos would help with a more definitive answer.
Umm. You don't connect an input from the receiver to a speaker. That would be an output. I think you better look at it again.
pentzy
Oct 26, 2013
3
Oct 26, 2013
3
I attached some pictures, sorry for the 'input/output' confusion. I believe that my current sub is powered through the +/- connection that ran to the home theatre system and that I need a sub with its own power source to use the signal cable. You can see I am holding the signal cable next to the input plug. Thanks for the help
solo2racr
Aug 21, 2013
142
Aug 21, 2013
142
Yep......Just as I suspected. The receiver needs a powered sub and the sub you have is un-powered. A separate mono amp here would be applicable.
pentzy
Oct 26, 2013
3
Oct 26, 2013
3
Or I could just choose to go with a different sub? I don't even know what type of sub to search for. Do I search for a powered sub? When I look at the photos I don't see them with the same output plug. Some I have seen have a left/right output, do I just use left or right?
solo2racr
Aug 21, 2013
142
Aug 21, 2013
142
Yea....just search for a powered sub. The left/right on the outside will be summed inside so you should be able to plug into either. And on the sub, it would be an input. Output would be from the receiver.
